M
Matts VC
Guest
Hi all
I've got a VC Commodore and stripped the nylon gear on the distributor.
I replaced it no problem but the rotten thing stripped again within 20-30 kms. Any ideas why? I have a manual and have followed the instructions for replacing the distributor.
Things I've thought of and heard of:
- Some wear at the front of the camshaft letting it move backwards and forwards. I've been told this can happen but it seemed ok when I checked it. The check consisted of carefully putting a screw driver through the hole in the block onto the gear on the camshaft and trying to move the camshaft backwards and forward. It didn't move.
- The oil pump may be shot. I've also been told this may cause it. I pulled the oil pump out last night and am going to replace it. I wouldn't know if the oil pump is gone (it seems to turn ok) but am going to replace it at any rate.
- A bearing gone in the distributor causing it to sieze occasionally. This is a real guess of mine beacuse the distributor seems to be turning ok.
Thanks for the help
Thanks for the help
