Strut brace fitting
BOGANV8
I gotta V8 whoot whoot
41
Armidale
VX 02 SS LS1
Had a quick search couldnt find anything...
Just bought a strut brace off ebay for $65 bucks going to fit it tomoz morn
Do you have to drop the springs out to get the bolts in from underneath or can it be done without dropping them
Car is VX SS any help you guys have would be great will post some pics in my ride when i am done
Cheers Dave
accentstencil
68
Eschol Park, Sydney
WH II Caprice, 5.7 2018 Equinox LTZ V
I haven't done it myself but I have heard that you will need to drop the struts to fit the bolts.
BOGANV8
41
Armidale
VX 02 SS LS1
Are thats what i didnt wanna hear :bang: :bang: :bang: :bang:
WAGON MAN
Gas Sleeper
North Coast , NSW
VX S2 Berlina Wagon with Phreddied bits.
As accentstencil said you will have to drop the struts....
Bogan V8, did "nrap" supply you with the bolts?
When you do it , could you take some photos of the installation and post them up?
Good luck;)
BOGANV8
41
Armidale
VX 02 SS LS1
Good luck;)
Nah they didnt went a bought some this morning only 3 bucks for the bolts
will get pics of install when i do it tomoz
Any idea how to remove the struts is it just the bolt on top or will that let the whole spring go and i will end up in a big mess
VTPREDATOR
34
Warwick
VE SS SPORTSWAGON
remove the top strut cover, (spring wont come out, theres an inside cover for that). then theres the two bolts at the bottom of the strut and a few fiddly things like brake hose clip etc. piece of piss.
BOGANV8
41
Armidale
VX 02 SS LS1
cool i hoping i wont have to go as far as doing the bottom bolts just the top one and let it hand just enough to get the nuts in there
will attack tomorrow and post up pics when im done
genIIIbandit
45
reservoir,melbourne
VX Series II SS BLACK M6
When removing the front struts the camber will be altered, requiring a wheel alignment.
EXCESSV
Perth, WA
VE SSV
unless there is studs sitting out on top of the strut tower then your gonna have to pull off the struts...
its a pain of a job so good luck with it
BOGANV8
41
Armidale
VX 02 SS LS1
But if i only remove the top nut in the engine bay and let the spring fal should be o.k
It should only need a wheel alignment if you remove the whole strut from the vehicle....
