Swapping out motor in my VE from a 5speed trans into my 6 speed trans ?
ChrisGood1
39
Australia
Ve calais sportswagon
Is there any difference in motors from a 5speed to a 6speed ?
Having trouble with spinning pulley once Trans in on .
What could cause this ?
Keeping in mind starter is off .
MACE
Hi Chris,
From my understanding the bolt pattern is the same, assuming you're using a 6L45 or 6L50 transmission.
However, there could be differences between the flex plate that is used between the 5 and 6 speed transmissions, which could be the reason why it's binding up.
This aside, the other main issue you may come across is having the 6 auto speed trans, being able to talk to your existing engine ECU
Hope this helps.
Kind Regards,
Michael
MACE
Hi Chris,
Hope this helps.
Kind Regards,
Michael
ChrisGood1
39
Australia
Hi Chris,
Hope this helps.
Kind Regards,
Michael
Thank you Micheal . Appreciate your reply.
Do you think the Torque converter could be installed wrong ? As in not fully engaged in the transmission?
Thank you
MACE
Thank you
"Thank you Micheal . Appreciate your reply."
We are happy to help you :)
"Do you think the Torque converter could be installed wrong ? As in not fully engaged in the transmission?"
It could be, however, honestly, it is hard to say anything without having a look. Your best bet would be to get a professional look to be 100% sure.
losh1971
North Tas
VE Series I SS Ute
If your converter is installed wrong then the pump will be damaged as a result.
losh1971
North Tas
VE Series I SS Ute
losh1971
North Tas
VE Series I SS Ute
