Tacho not working
Bazmlb
Queenstown Tasmania
VX series 2 Acclaim Wagon, 3.8 FE2 suspension
I just got vs, it has just been converted to 5 speed manual. Now the tacho doesnt work,I dont think RPM up of the flywheel, any help appreciate
Brysha89
34
Melton,Victoria
WM Statesman L98 6.0ltr
could be as simple as a faulty transmission speed sensor or something major get it looked at by a mechanic if possable. Did you do the convert? or buy it like so?
BlackVXGTS
Melbourne, SE
The tacho signal comes from the ignition coil. Make sure you don't have any loose connections like in the attached diagram:
Bazmlb
Queenstown Tasmania
Thanks I will check all this out and come back with the results
