tapping noise in engine
cbb01
Ipswich
SUPERCHARGED VP COMMODORE
ok only started this morning
started the car and i usually let the car sit for a few minutes before driving and i noticed a slight tapping noise ( i dont know anything about engines ) but sounded like the lifter at the rear was tapping and not getting any oil. With a bit of acceleration the tapping noise was faster and louder. I had to go to work and under idle couldn't hear anything but driving was pretty noisy. After a few minutes it did go away . I only work five minutes MAX away and by the time i got there it was gone.
Now before any comments on oil
It is regularly serviced ( only 4500km ago ) Six months
There is oil! And good quality clean oil!
It just sounds like the one isnt pumping any oil but after a few minutes the others lubricate this one up ??????????????????????????????????????????
There is no power loss ( that i can notice but i have driven it very carefully obviousley)
Any ideas what it is so i have an idea when i go to get it looked at on Monday
Any help Thanks
cbb01
Ipswich
cbb01
Ipswich
no
there is the usual tap from the injectors but this is definatley in the engine
thanks anyway.
anyone had similar prob. with only one rocker being noisy
seal? not getting any oil???
i dont know
As i said there is no power loss and no smoke whatsoever coming out the back.
After 5 minutes ok sounds like normal but just the one
fitzy2005
Wide Bay, Queensland
VY S2 Berlina
take rocker cover off and tighten all the rocker arm bolts, hope helps, if not try using Lifter Free its about 10 bux a bottle
prince_dj666
hypo v6
QLD
www.cardomain.com
http://www.cardomain.com/ride/2112842/1
my car now does that.... did oil change and it started making tapping sounds. so i did another oil change with diff brand of oil and lifter juice and it still does it.. starting to get worse now. also fuel economy has dropped.. from 450-470 a tank to 330-350 a tank.
Don Sutton
73
VS Commodore Acclaim
If it is a single hydraulic tappet bleeding down, then it will not make a noise every time the engine is left for a while as the engine stops in any one of 3 places on a 6 cylinder. It bleeds down when the valve has to be held open against valve spring pressure and then takes a while to fill with oil as they have a small hole to let the oil in. If an engine is sludged or poor quality oil is used this is more likely to happen. The lifters can wear depending on the quality of heat treatment of the wearing parts over which you have no control. You can try a Nulon additive for lifters and if it works OK otherwise they can be pulled apart individually unless you follow a regime of keeping all lifter parts in discreet containers. The valve can sometimes be turned upside down and lapped with jewllers rouge or the like if you are that desparate but simply replacing the faulty one is the best. Also look at the rocker incase this has wear. The hardest job will be locating the offender - thank your lucky stars you dont have a 24 valve engine. Holden have a time for the lifters to stop making a noise but is designed to avoid warranty claims something like 3 minutes per start.
cbb01
Ipswich
yea i know where the offender is. He is the only noisy bastard there. So hopefully will just be the one loose rocker :bow:
will have a look tomorrow .
Thanks for all comments and let you know.
nathans1987
33
W.A. Perth
4316.awardspace.com
VX SS 5.7L M6
sounds like a noisy tappet normaly caused by not enough oil. its not really serious. try an oil filter and oil change see if that fixes it.
M
MavVP
Guest
I have a similar tapping noise but i have a small hole in my manifold that is causing it, might look there as well
