ncass11
- Sep 29, 2011
- 171
- 5
- 18
- Location
- cairns, QLD
- '81 Diesel Hilux / '75 Landrover series 3
found the issue with the 4wd H-range not engaging, removed the tin cover at the front of the transfer and found the shaft was sticking so a little WD-40 and all good
its the spring loaded shaft in the middle with the hole for the pin, the pin locks it out of 4wd and when the pin is raised up the shaft will slide out by a spring engaging 4wd H-range
im going to go over the box a bit more and replace some seals as i might as well while its out and they have been in the box for over 10 yrs with no oil so best to be safe
