losh1971
- Jan 17, 2010
- 22,779
- 22,703
- 113
- Location
- North Tas
- VE Series I SS Ute
Camper worked great all weekend. The solar set up was able to keep the deep cycle battery charged while running phone charging and a fridge that rarely switched off during the day. I reckon I can even run an inverter at some point. I'll add a sine wave one to my wish-list. I have a modified square wave, which can do some things, but sine wave is really the go as they are more efficient.
The Bunnings camp kitchen was faulty so it was returned tonight and I got my money back. There was a manufacturing fault, which meant the wind barrier didn't slot into its groove. Somehow the the ali top had slits at the front but the back slits were underneath so the wind barrier would move and not drop in. I was offered a swap, which I declined thinking others may be the same. Instead I think I have an old wooden fold up table in the shed. I will use that instead.
Decided to leave basically everything in the trailer ready for the next trip, rather than pack it back on the camping shelves. Couple of things I need to sort. One is being prepared for unlevel ground. The other is I need about another 40-50mm of height so the tent sides don't sag. I thought about my options, one was raise the wooden sub-frame by adding in another lot of timber. Then I thought about 16s. Both will cost money, so I have decided to carry timber blocks and slip those under the wheels. I also need to find another cheap screw jack to use as another stabiliser that I can raise to get the trailer level. So far I have one from the old Jeep, which worked great. I just need to pack the winder handle as a screwdriver wasn't the easiest method of winding it up. I can probably get away with a jack stand in the interim as I don't want to pay any more than $10 for another jack. The other thing I didn't think I would need was a multi-meter. I used to take one camping to keep and eye on the battery voltage, prior to having the panel. I needed it this time as well as I thought the battery was down below the recommended 11.8v. Turned out when I tested after getting home it was about 12.2v, so probably had a few more hours on the fridge without the panel when we were packing up. Having said that inbuilt lithium battery was enough to keep he fridge running for a few hours after disconnecting it from the main battery.
