DIVISION 9-BRAKE LIGHTS
Fitting brake lights
98. (1) A brake light must be fitted to the rear of a vehicle built after 1934.
(2) A pair of brake lights must be fitted to the rear of:
(a) a motor vehicle built after 1959 that has 4 or more wheels; and
(b) a motor trike built after 1959 that has 2 rear wheels; and
(c) a trailer built after June 1973.
(3) The centre of a brake light must be:
(a) at least 350 millimetres above ground level; and
(b) not over:
(i) 1.5 metres above ground level; or
(ii) if it is not practicable to fit the light lower-2.1 metres above ground level.
(4) A vehicle may be fitted with 1 or more additional brake lights.
(5) The centre of an additional brake light must be at least 350 millimetres above ground level.
(6) If only 1 brake light is fitted to a vehicle, it must be fitted in the centre or to the right of the centre of the vehicle's rear.
(7) Subrule (6) applies to a motor bike with an attached sidecar as if the sidecar were not attached.
Location of brake lights on a vehicle
Performance and operation of brake lights
99. (1) When on, a brake light must show a red light visible 30 metres from the rear of the vehicle.
(2) A brake light fitted to a street rod vehicle may incorporate a blue lens not over 20 millimetres in diameter.
(3) A brake light fitted to a motor vehicle must come on, if it is not already on, when:
(a) for a vehicle with 4 or more wheels or built after 1974-a service brake is applied; or
(b) for another vehicle-the rear wheel brake is applied.
(4) Subrule (3) does not apply if the controls in the vehicle that start the engine are in a position that makes it impossible for the engine to operate.
(5) A brake light on a trailer must come on when:
(a) the brake light of the towing vehicle comes on; or
(b) a brake control on the towing vehicle, which independently activates the service brake on the trailer, is operated.
(6) A brake light may be operated by an engine brake, retarder, or similar device if the device does not interfere with the proper operation of the brake light.
(7) A street rod vehicle is a vehicle that has been modified for safe road use and that:
(a) has a body and frame that were built before 1949; or
(b) is a replica of a vehicle the body and frame of which were built before 1949.
