_R_J_K_
- Dec 20, 2008
- 6,723
- 1,856
- 113
- Zenki S14
Usually you log into some kind of website or platform or app to view its location data, basically the same as Maps location data when location services on your phone are turned on. The more basic trackers (or phones) don't "know" when they've been stolen necessarily, they just report location data back to whatever platform it uses, no messages or anything but you know where the car is. Like Norti says, you could probably setup something a little more complex with these, but would need to link a bunch of stuff together with automation and API calls.What i can't get my head around is if the tracker is "on" and being driven around wont you get messages from it all the time?? That would be annoying and sort of useless. It would be like tracking yourself 99.9% of the time?
There are more encompassing systems where you can setup designated areas and boundaries, view car parameters like speed and ignition status, alarm status also. You may also be able to setup device proximity alerts where you're alerted if the car moves and your phone or something isn't close. Keep in mind though, if you're parked in public and your car is easily able to be started without the key (or they've stolen the key), by the time you have an alert that the car is started or has reached a boundary, the car is going to be long gone by the time you get back to where you left it. It's why the messages are kind of moot in some cases and a location services type map can be just as helpful.
Unless you're being specifically targeted by a group with a tilt tray, it's easy to protect against basic opportunists and joy riders so before going down the rabbit hole of GPS trackers I'd look at the basics - look at what deterrents are already in your car first. I assume this is in relation to your VK, in which case I assume you already have an immobiliser. Most immobiliser installs are hot garbage, even professional ones. Realistically, an immobiliser should be a dash out job to hide it in a hard to get to place behind the dash - this is where most people I know who have installed their own (myself included) put it. If your immobiliser module is easily accessible by hand (so many are just cable tied to the steering column), then it's pretty much worthless as thieves can easily pull the casing apart and bridge the immobiliser circuits.
