Forkboy78
Does anyone know the torque setting for front caster bushing on vz Commodore I recently done mine and torque wrench 24nu the torque wrench only went to 24nu anyway then it's foot pound per square inch if that's how it's said
FrontFront Control arm nut is 148 Nm.
Control arm insulating bush is 23Nm
Control arm ball joint 60Nm
Control Arm inner pivot bolt 100Nm
Best I can find for you.
The front control arm nut is that the caster bush at the front with big bolt...thankyou for your help so far
Thankyou for the help so far...do you know if the front control arm
thankyou for help 99notout do you know which one is the big caster bush at the front of the car
Thankyou for the help 99notout after reading all that info I'm pretty sure I have work
Thankyou for the help 99notout after reading all that info I'm pretty sure I have worked out which one is the caster bush bolt
But one more question I've had a wheel alignment done after replacing bushes if I tightened the caster bush bolt at the font of car to 148nm would that throw the wheel alignment out
