Turbo V6?
greenfoam
102
VP Executive R-spec
Above 6 psi you would need to start making heaps less spark advance because the inlet charge will be so hot
greenfoam
102
VP Executive R-spec
Here's some compressor maps, I have heaaaaaaps more, just name the turbo
1vngal
North Tassie
'Ruby' 1991 VN Exec & '98 Proton M21 Coupe
Ruby should be turbo...Or supercharged!! She needs more power....
Foam, what do those compressor map thingys show? I can never read those sort of things...
greenfoam
102
VP Executive R-spec
Yeah VN2NV, you can gain heaps of power just from the cooler air, let alone being able to run full spark advance (but it costs more:) )
1vngal, compressor maps help you decide what turbo to use on your engine, it pretty complex stuff, toooooo complex for 4 am that's for sure
1vngal
North Tassie
So, if you're to turbo a V6, you'd be much better off running an intercooler? Do you have to have one? I have no idea....
greenfoam
102
VP Executive R-spec
Better off yes, but you don't need one if you are running a small amount of boost, the extra pipes to hook one up can get a bit tricky
1vngal
North Tassie
Ok, cool. I get it now. Thanks Foam!!!
NVE_069
Wh Statesman LS1
whats better to run external or internal wastegate. and how to u determan the amount of boost it will run or is that all in with the tune. as far as i have read an been told for a stock motor do long as its healthy it should be rite for up to the 8 9 psi?
im just haven a hard time tryn to pick either turbo or super lol i know with the super shes a bolt on job but turbo is too but doin it ebay so to speak way prob take longer.
