UFO
I Believe
- Oct 29, 2009
- 1,860
- 20
- 38
- Location
- Canberra
- MY10 VE International Sportwagon SIDI 3L
I dont know about 7psi, but 304runner does make a valid point- most modern engines will handle a low boost set up no worries. I'd be keeping it to 5psi tops (just to make sure the rest of the drivetrain is up to the task), but otherwise should all be sweet. Setting up a twin turbo setup will be very expensive though.... a hell of a lot more plumbing to do. If you want something different, I'd consider going for a single turbo on a different engine- say a SIDI with single exhaust port. The money you save might warrant the car upgrade, and it'll be a very nice base to work with. Mind you, if you're going to change cars, then may as well go an 8 and be done with it .
