turning a vc commodore to a vk lookalike
H
hdt_077
Guest
hey guys my son and i are working on his vc commodore and when we brought it, it already had the vk bumper and tail lights.We brought a vh commie for the front guards and bonnet and when we went to put the vh guards on the vc commodore but discoverd that where the headlights sit are different to the vh commie.So my question is can we still turn the car into a vk with a little bit of cutting or is there another way to do it.
All response in regards to this project will help heaps thanks.
SL/ENUT
The SL/E Fanatic!
Burnie, Tasmania
VB SL/E 5L
use VH/VK headlights, thats all you need.
H
hdt_077
Guest
cheers for your reponse on my topic SL/ENUT,so i dont have to cut any of the indicator framework on the VC commie to fit VK guards and lights is that right
1vngal
33
North Tassie
'Ruby' 1991 VN Exec & '98 Proton M21 Coupe
My ex had a VB with a VH front end on it. The only problem that had was the bonnet was a little hard to open. Whether the clowns that did the conversion, didn't line it up right, or whether there needs to be some sort of modification, I don't know....
Just something to keep in mind.
greenfoam
99
VP Executive R-spec
I believe you do need to do some slight cutting to fit the bigger lights! the reason I say this is because I've seen and read a how-to on the net before, unless that was keeping the VB bits and just going to the bigger lights, I can't remember perfectly. Also 1vngal, the bonnets are a bit different
