Fu Manchu
- Mar 18, 2006
- 17,973
- 22,703
- 113
- Location
- WA.
- VZ Crewman, VZ Cross 8, & ya mum.
Vacuum to the tap is not the problem, because I wired the tap closed and still had the problem. A new development is that I removed the tap altogether and replaced it with a solid plug, stopping any water flow. This temporarily solved the problem and my airflow into the cab returned to normal outside air temperature, like it used to be. When I blow through the removed tap with my mouth, some air does leak through, even though this is a new tap. Thinking that I had bought a dodgey tap (through the internet), I ordered one through my local Holden dealer. When I went to pick it up, I tried the blow-through test, and that one behaved the same - you could blow air through while holding the lever closed. The attendant then took it out the back and tried it with water. He said yes, some water does leak through when closed. How hard can it be to make a simple tap that closes off properly? Any plumbing store would have one. Anyway, I told them there was no point buying another tap just like the one I had so I'm back to square 1. I think I've eliminated everything except perhaps that a dribble of water is supposed to pass through, and my problem is that the air mix flap on my car is not sealing off properly. However, one of the 3 service centres that I have paid to look at this said that they checked on that. I will have to do it myself. But i can't find out how to get at it. Can anyone advise how I expose the warm/cold air flap, that I believe is down by the left foot rest? I can't see it or how to get at it. Will try flushing heater core - but I can't see how that would be a cause of too much heat, only the other way. Thanks.
It would be logical that a small amount of flow is allowed through, to avoid coolant just sitting. It wouldn't be enough to make the difference you are experiencing.
Be worth checking the knob for the temperature.
Remove the assembly from above the headunit, give it visual check over and focus on the part at the back that controls the temp. It's a lever thing.
The arm for the internal flap that restricts hot air might be dickie.
There could easily be some foam stuck in the flap allowing air to circulate through the heater core compartment (which won't cool immediately) Adhesive foam is used around the edges of the flaps... no wait I'll use the word doors, around the edges of the doors in the HVAC. They drop away and get brittle/crumble etc. I found heaps in the VE HVAC when I pulled that apart.
Have you got climate control or a manual HVAC control?
