Updated VL Walky Replica (Work in progress) Please use this thread from now on
*uwishn*
Holden special vehicles
sydney
vl walkinshaw(replica)nissan navara d40 st-x turbo
whens the update coming : )
Jonno
Vic,
The one on the left is the one i think you spotted jonno, the one on the right is what i think is another crack having a close look at that photo......[/IMG]
i was talking bout the 1 thats like in the middle brothher
Nackerz
Rollin
2 n/a vl's 1 twin turbo vl vn ss vy sv8
Nackerz
Rollin
Nackerz
Rollin
Ok so we just brought a VN SS, so this will not be ready for c4c. Been working on the ss and have no time to finish this. Currently getting a rwc on the ss to transfer it into my name.
Since this won’t be ready for c4c, I will let you all know what is getting done; otherwise it will be longer you will have to wait. So here goes :)
Engine work was done at a shop in Melbourne. Here is what is on the receipt:
Head is 55.5cc
Valve spring set
Cam Turbo ST2, Crow Cams
Degrease Block
Linish a Crankshaft, STD Size
Bore & Hone Block, 1mm Oversize
Drill out oil plugs on crank & retap for Screw in plugs
Dis, Ass & Align rods
Balance Engine
Surface block
Reco Head, Fit turbo Ex Valves
Supply & fit K-Line guides, Ex only
Assemble to long engine
Match porting on In, Ex
Valve seat inserts, Turbo heavy duty
Water pump
Con-rod bearing set, ACL Performance
Main bearing set, ACL Performance
Ex valve RB30 Nissan
Oil pump Nissan Hi Volume
Full gasket set
Head gasket, Race series turbo, Connetec
Timing belt RB30 Nissan
Belt tensioner RB30 Nissan
Valve Lifter, RB30 Nissan
ARP Head stud Kit RB30
Welch Plugs, Brass
Piston Forged Nissan RB30, Flat tops 1mm
That’s the engine side of things. The 5 speed was also Reco’d.
Now for what’s getting bolted to it :D
Custom high mount twin turbo steampipe manifold
R33 GTR Turbo’s (Gates welded closed)
50mm External Wastegate
2 ½” Dump pipes into 3” Exhaust with Hi-Flow cat
Front mount intercooler 600x400x100
Along with:
Microtech x6 ignition module (Already have)
Microtech Lt16’s
Injectors
Coil Packs
Fuel system
28 Spline LSD (Already Have)
Maybe some other stuff.
The Lt16’s, coil packs and the software etc I’m getting as a package.
Still need to get them plus Injectors and fuel system.
Have also got the lower side skirts for the body kit, just need to chase up the front and rear lower lip.
I’m smoothing the bay, Hiding the wiring and painting the bay also when I do the engine swap.
I have just spent a fair bit and brought all braided lines from Luke at missile performance (Duke57TT) I can say that his stuff is top quality and will never buy any other stuff. Very easy to use and make the lines up. He is a great guy with good communication, fast postage and great prices! He is by far one of the best sellers on CT.
Anyways, there is some info you can read, I hope you will all enjoy it and I can say, I can’t wait to have this all up and running. I wouldn’t mind seeing what power this thing will make.
*uwishn*
sydney
nice mate be sick when its done,i would hate to see your bank balance haha
Nackerz
Rollin
