upgrading audio but keeping holden audio unit in. anyone else done it?
dmp8810
Gold Coast QLD
07 VE SV6
07 VE SV6 SEDAN.
want to upgrade audio but keep holden audio unit.
so was thinking
replace 6 speakers ( mid ranges and 2 tweeters ) and leave the centre speaker in.
just add a line converter so i can amp my 7 speakers.
Whats a good brand line converter? was thinking of getting all the gear from jaycar. just want a bit better sound.not COMP style haha.
and down the track add a sub.
and does anyone know what the SV6 has stock for each speakers RMS? or where could i find this info?
illlusion
VE SSV MY10
Disconnect the centre speaker it will sound heaps better the door speakers are 15w or 30w mine where 30w i have mine running through a Audison bit 10 processor to my Amps so I don't use a line output converter but for what you want replace front and rear door speakers and tweeters get a line output converter for your amp will work
UFO
I Believe
MY10 VE International Sportwagon SIDI 3L
+1 remove center speaker.
and if you are going to go to the trouble of opening doors to replace speakers, while youre in there dynamat them.
a mate did just that (after he'd already done speakers earlier) and we all noticed a difference.
if you got a limited budget, concentrate on the best speakers you can afford and go a little cheaper on the amp and high level converter (jaycar etc).
BigBoss
VE Omega
It saves some stuffing about if you get an amp with high level inputs. This way you don't need a loc (one less link in the chain) and you don't run the risk of the loc letting you down quality wise either.
dmp8810
Gold Coast QLD
07 VE SV6
ok but where can i find out how many watts RMS the VE SV6 speakers are? so i can work out a worth while improvement on speakers.
Oh, you can get line converters from JAYCAR?
BigBoss
VE Omega
The stock speakers are utter crap, they are around 20rms from memory. Just about anything you get will be an improvement.
nickb1993
sydney
ve sv6 ute
Anyone know how deep i can go with door speakers in a sv6 ute without changing anything?
VTSS350
Blown VT LS1 450rwhp
47
VTLS1
I put an 18mm MDF spacer behind my speakers.
I used Focal K2s and highly recomend them.
I also highly suggest you buy a bulk pack of dynamat and do the door skins.
BigBoss
VE Omega
Personally I would only dynamat if you were amping the system.
