s_ikari2015
Fun IS easier with an 8
- Nov 16, 2007
- 697
- 30
- 28
- Location
- Australia
- '02 Monaro V2 CV8, '90 Toyota Sera
I changed the disc rotors and pads on the weekend as well as the front wheel hubs on my VT. Now there's a terrible clunking coming from the front left whenever I brake.
I had a look at the brakes but couldn't find anything so I booked it into Holden this morning for them to check it out.
This is what they claim:
The front sway bar bushes and link bushes are cracked and worn out. The lower control arm bushes are also cracked and worn out. They claim the whole suspension is moving forward and back again thus the clunking. They said it will cost over $1,100 to fix. :rip:
I can only assume the new discs and pads have put additional stress on the failing bushes and when I first used the brakes they gave way? This is absolute boulderdash in my mind. I've had the sway bar link bushes changed twice in the last 2 years, and the service technician has said that they don't make Nolathane bushes for the link kit... Are you kidding me? If it's a rubber bush then there will be a Nolathane equivilent.
Also, the handbrake light won't turn off. They claim it's because the brake fluid needs bleeding. They say there's a sensor in the brake line that activates the handbrake light. But the handbrake is a cable operated system... is this further boulderdash?:bang:
I'm going to insist on seeing the old bushes. Something just doesn't feel right about all this.
EDIT: They also say it won't affect the steering at all, is this true?
