If the set you got came out of a car that had ABS and you haven’t got a compatible ABS module connected the BCM would be polling the ABS unit looking for a response. The BCM is considered the Bus Master and part of its job is to poll every module on the bus. Every 300ms it sends a message and expects a return message called a State of Health message (not that it matters but it polls the ECM every 150ms)
If I’m even right I believe you either need to get a different set, or if it’s even possible get the software flashed on the BCM to not expect a SOH message from the ABS, or learn how to flip the required bits in the BIN file on the BCM or get one of those boxes that one of the PCMHacking guys sells to add the required SOH message to the heartbeat that gets sent on the bus every 300ms
