Urgent help!
Immortality
Staff member
Sth Auck, NZ
Only one thread per topic as per the forum rules.
Threads merged!
Immortality
Staff member
Sth Auck, NZ
Grimes
NSW
VS Commodore Series II Ute
I have no clue what to do and what’s right
Follow the instructions in the link by bridging these two with a paper clip wire with the ignition on. Code 1-2 will flash three times then your first error code, followed by any others.
Walshy3551
22
Lakesland
1996 Vs Executive sedan 3.8 ecotec
I got engine code 94
Grimes
NSW
The ECU isn’t getting a speed signal from the transmission. When you converted, did you replace the ECU with one that’s matched to the gearbox? Automatics, T5 and Getrags have their own ECU program/tune to accept the different signals received.
Check to make sure the speed sensor is still connected to the transmission too. It’s held on with a small hex screw.
The sensor cable also has a white plastic inline connector that will be just inside the trans tunnel. Make sure it’s still connected too.
Walshy3551
22
Lakesland
I’m not too sure how to do all of this hey I’m still new to this
