V6 white smoke, but not always
Taranaki
New Plymouth
Calais
This one has been driving me nuts. Ecotec done about 300,000 km (odometer display died). When you start it first thing in the morning, misfires on 2 cylinders, and spews white smoke, smell of unburnt petrol. Seemed like bad DFI coil, replaced them and DFI module - no change. White smoke suggests head or intake manifold gasket. I have monitored coolant, and it is not losing any. Cannot see oil in coolant either. Now the strange part is you can let it run until temperate gets up to 1/4 then stop engine. Come back 2 hours later, start engine - no misfire, no smoke. So it is like heat soak cures the problem, whatever it is. Has error code 76 (trim left-right differs too much).
lout
60
Langwarrin Victoria
white smoke is generally coolant, i would start with lim gaskets as these are extremely common to fail
