V8 dizzy, I can't turn it
Alspos
VK V8 Sedan
Hey there,
I'm gunna burn this friggin POS car in a minute.
I'm trying to adjust the timing of my V8 VN and I can't get the dizzy to rotate. I've undone the retaining bolt (why holden made it so bloody hard to get to I'll never know) but the dizzy is stuck fast. I've tried all I can think of and brute force to rotate it...still no luck. I don't want to whack againt the connector on the side, my luck it will break straight off.
Any tips before this thing becomes a bonfire please? :mad:
Immortality
Staff member
Sth Auck, NZ
have you tried soaking it with WD40 or CRC556. try spraying it when the engine is hot as the heat helps draw the the lubricant in
Vt-Brrrlina
vp bt1 gts replica
Perth, Western Aust
vp bt1 5.0ltr full GTS kit
it shouldnt be hard to turn trust me - ive had similar problems mate - yeh try some crc or wd40 mine wasnt loose loose but not tight to turn either - i have a borken thumb and still managed to move it - dont burn it lol - i need a new engine to play with ha ha
Alspos
VK V8 Sedan
Thanks for the replies....sprayed with WD40....I can only assume some got in the right place. Left it for 20 minutes and had another crack at it....all good now, bonfire averted.
Morton
For external use only
Fairstar the Funship
I still insist there would have been a way to remove it with the inlet manifold on, Mack ;) You're just weak.
stocky
i dont know why you guys have so many issues with your dizzys. mine turned fine, and came out easily. did require a bit of phone assistance from rope boy above though
Emackulation
Banned
SE Queensland
'92 HSV VP GTS
Lol, I had my mani off already anyway so it was easier. But as Stocky said, his was fine, it just luck of the draw, some are in there hardcore and others are pussy's (like Stocky, lol) Morton's was intermediate.
Morton
Nah mate, mine was hardcore. You're just a softcock.
I thought you called me "rape boy" for a minute there. You had me worried :p
