v8 pushrod bent
squiblex
UNSEEN
34
SA great mate!!
VK 308
hey i have a old holden 308 it has a bit of head work and a cam, it had a bit of a knock commin from the top wen i bought it i found it was one of the rockers looked loose wen i pulled the rocker cover off i took the roker set off that was loose an found that one of the pushrods was bent pretty bad!! wat would cause that?? an how do i kno if it will do it again wen i put a replacement back in??
Pub247
Melbourne S.E.
Ford Fairmont
seen it heaps quite common especially when you flog the crap out of them
squiblex
UNSEEN
34
SA great mate!!
VK 308
ways a good solution to fix it from happenin again??? an would it done any damage to the inside of the moter???
VK SL 3800
VK SL 5spd
Probably woulndt have hurt it, its only going to rub on the head a little if its really bent other then that there not too much else it could do.
Tree cutter
Tree cutter
Mt Gambier SA
VX Calais SuperchargedV6
Bent push rods are normally caused from valve bouncing. The valve springs might be a bit weak or it might be that someone has just thrashed the guts out of it.
