grantius
- Dec 22, 2013
- 53
- 0
- 6
- Location
- Auckland, NZ
- VK Berlina
Hey guys,
Since ripping out the EST computer I've been driving around without the vacuum advance attached so I've decided to attach it so I get better fuel economy.
Question - I've hooked up the vacuum advance to intake vacuum as AFAIK there isn't any ported vacuum on the EST carb. Is this the way these dizzy's work? Most advance at max intake vacuum and as vacuum drops the timing is pulled? Or the other way around?
It idles a bit high after connection - around 700rpm when disconnected and close to 1600 RPM when connected - is this normal? From what I've read the extra timing shouldn't rise the idle RPM that much.
And if I now turn the idle screw down so it idles around 700 will that be all I'll need to do tuning wise?
If it is a stock replacement blue motor dizzy I'd think it won't ping when cruising as it's not exactly an aggressive tune. At the moment I can run 91 without issues but if I notice any pinging at light throttle I'll fill up with 98
Thanks
Thanks
