VB sedan from 8 bolt open (small) Salisbury diff to VL Borg Warner. Tail shaft questions.
HazzaHolden
45
VB 304 T5, VY SV8 Turbo T56, VE SSV Blower TR6060
This era Commodores have 2 different size CV's....90MM and 100MM from memory.....You have to physcially measure them to see if you have the right size CV...So it's not as simple as unbolting and re-bolting with that.
Thanks for the info. Is it safe to assume a n/a 6cyl VL tail shaft CV is the smaller one (90mm)? If so I just need to measure my current one (being a VB 253 car with small open diff Salisbury I am confident it is smaller one too) and that would confirm it.
vc commodore
Like the Leyland Brothers
VC, VH and VY
Thanks for the info. Is it safe to assume a n/a 6cyl VL tail shaft CV is 90mm? If so I just need to measure my current one (being a VB 253 car with small open diff Salisbury I am confident it is 90mm) and that would confirm it.
I honestly don't know the CV diametre with it...You have to measure...
Same applies with your current tailshaft.....
I personally have 2 tailshafts here from early Commodores....1 is a 3.3 auto drum braked rear VB Commodore, with the smaller diametre C.V and the 2nd is a VC 6 cyl 5 speed disc braked diff, with the larger C.V.....
So don't take it for granted....Take measurements so you don't get caught
HazzaHolden
45
Wow, yeah smorgasbord. I haven't bought the VL 6cyl n/a tailshaft yet so can't measure. But I will measure my current one, and see if the seller can measure the VL 6cyl n/a one. Thanks again for all the info. PS - I found hiy-po's pics from a previous thread. The larger one looks like 100mm OD (90mm bolt hole centre to centre). Smaller one prob 94mm OD.
vc commodore
VC, VH and VY
View attachment 268377View attachment 268378
Honestly I can't remember thee exact diamentions...It was 6 years or so years ago I bought another C.V, which is when I found the differences....
Memory wise, it is outer edge to outer edge...
HazzaHolden
45
I have confirmed the heavy duty CV is 100mm OD, and the regular CV is 94mm. The VL 6cyl n/a uses the 94mm from all reports. Not sure what my VB 253 small 8 bolt Salisbury non lsd disc braked came with, so going to get under and measure on the weekend. My guess is it will be the 94mm. The 100mm CV was probably reserved for the 308 large 10 bolt Salisbury or disc braked rear ends.
HazzaHolden
45
Ok so my CV is 100mm OD. It must have been upgraded when the 304/T5 were put in. Anyone know ballpark figure for shortening of a tail shaft? I have a VS V8 rear half that is 100mm OD I can use but its too long.
vc commodore
VC, VH and VY
Going back to 2020 ish, I had a tailshaft shortened 25MM, new unis + uni holder, new C.V+ balancing through Hardie Spicer for $600 ish...
HazzaHolden
45
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
HazzaHolden
45
$600.00 or $590.00. + what's the delivery charge?
I can pickup for free as I go to Sydney a few times a year. And like I said, that was 4 years ago, so likely be more, plus the other option is brand new and includes a new front half too.
  • Like
Reactions: Lex
