Thanks NAAF, the answer I was looking for.
I don't believe I have had any more solid debris enter as Holden just did the 30,000k service after having the OTR on for over 10,000ks and said nothing. Given the mods and tune voiding most of my warranty I'm sure they would have taken any opportunity to try and milk some coin if they found even the slightest problem.
They wouldnt know anyway. The only thing theyd be able to tell you is there was dirt around the intake (if they even bothered to take it off, being a OTR im tipping they wouldnt have even looked at it unless you sat there and watched them). They certainly wouldnt tell you untill your piston/lifter/camshaft had cooked itself. Its not as if general servicing would come under warranty and typically thats the first years job and they sure as #### wouldnt know.
Bugs/small particles of dirt. Meh who cares.
Small rock/bouncing debris such as small screw heads etc. Sure, 1 in 100000 chance of it magically getting in there, but its a chance. Dirt etc may make it run a bit rough depending on the time it takes to build up around the intake. Id be mostly concerned about hitting a large puddle and a lot of water getting sucked up directly into the hole. End of the day. VCM acted in regards to reputation. Im sure youve seen how perdantic people get about absolutely everything no matter the actual chances of something going wrong.
Im running a Manta Twin 2 1/2 with 1 7/8 headers. Even just crusing around town, the exhaust isnt loud but certainly overshadows the intake.
