dakman
- Apr 28, 2009
- 119
- 0
- 0
- Location
- newcastle
- ve ute 22's lowered hardlid
i tried installing one on the weekend, it is possible. but it looked ugly and stuck out to far. arraprently clarion is designing something to get rid of the old unit and make it so you can put an aftermarket double din in place..
the black pipe behind the dash runs through your centre console. it is for the rear a/c but the ute doesnt have rear a/c but when i took mine apart the air still travelled through the black duct. so when you disconnect the black duct you have to block it so that air doesnt come through it anymore. whatever you block it with, make it good cause even when the a/c isnt on air comes through it.. i know all this cause i did it on the weekend and tried to sort it all out..
to take the centre console out. pry the black top covering off around the power window switch to the traction control switch. its just got clips on it and lifts straight off. and then just start unscrewing all the plastic pieces. use this as your starting point. you will work it all out from there.
hope this helps mate. i have 2 photos of this ill try and get them off my phone
