brettyj
- Jun 24, 2023
- 15
- 2
- 3
- Age
- 29
- Location
- Adelaide
- VE Calais 6ltr
You planning on replacing the balancer yourself? If yes you will need a special puller and the install kit. Don't try to use the crank bolt as some have unsuccessfully tried, or you will likely damage the crank snout, which tends to happen.
I've not long replaced mine and I know how important it was to have the correct gear before attempting it
Oh look I Think Il just leave it to the pros on this one sounds like needs a few things now. I don't think the balancer has to do with the choking issue .You planning on replacing the balancer yourself? If yes you will need a special puller and the install kit. Don't try to use the crank bolt as some have unsuccessfully tried, or you will likely damage the crank snout, which tends to happen.
I've not long replaced mine and I know how important it was to have the correct gear before attempting it.
It's only a slight wobble but It is a wobble and I assume anything other than centred is not alright? . I'm really not a mechanic lol but these forums have helped me out big time before and is nice to get a second opinion.
