Hi guys I'm going to put a oil catch can on but befor I order one of the cans what size is the tube? Don't want to buy a 12mm one when it's 9 or something.
Which breather line are you going off? You'll find it's more likely a 10mm inside diameter. Just make sure the hose you get is oil safe and not some cheap sh*t that will fail.
Thanks bigjim I don't no il see what ever one fits, haha what one should I be running it off? The one that goes straight into the intake or the hose that goes into the actuall intake silencer box?
I've posted in a thread with details on my install, but connect it up to the breather that goes to the centre of the manifold.
Post #44 http://forums.justcommodores.com.au/ve-holden-commodore-2006/201721-catch-cans-2.html
Just make sure your catch can has an air tight seal. Mine didn't at first, and it caused all sorts of issues (easy fix though)
