prktkljokr
- May 11, 2014
- 59
- 0
- 6
- Location
- Perth
- VE Omega, W204 Mercedes C180 coupe
Hi guys, First post here, but hoping someone can point me in the right direction.
I have some conflicting information regarding replacing the standard Omega radio unit over, I have a unit that has been damaged, and I have pulled a second hand unit from a wreck I bought for parts, I am only changing the unit and not the faceplate, both cars are 2007 Omega's and are identical apart from vin numbers, and radio codes.
I have rang a few dealers, some guys who say they are a wiz when it comes to Commodores, and spoken to a few techs with conflicting information, ill go with what the Holden tech's relayed to me.
I have been told by one Holden tech, that I need to clear the radio code from the unit I am removing from the wreck while it is still in the wreck, then I can then recode the radio once fitted to my car, they told me that this can be done with the tech 2 type tool.
Then from another Holden tech, I was told that the radio from the wreck can not be cleared with the tech 2 and needs to be sent to Bosch to be cleared/recoded.
Then just to confuse me some more, the 3rd tech I asked told me that if I bring both cars in they can change them over no ptoblem as long as the wreck powers up (which it does)
i have found a heap of posts regarding changing radios from series 2 into series 1, but could not find anything about replacing a series 1 radio with the same type unit
I have used a friends Tech 2 type tool and retreved the radio code and numbers from the wreck, but it did not have a section to remove codes from the radio.
Just getting a little frustrated, I have a tilt tray and can take the wreck to the dealer, just want to make sure that there is no way of solving this myself before I do so.
