VF Worksop manual states the following re tightening the rear wheel hub nut:
8.
Install the KM-468 hub holding tool (1) to the wheel hub (2) with two inverted wheel nuts (3).
Support the KM-468 hub holding tool (1) outer end on a safety stand.
Note: There are two suitable methods of tightening the wheel drive shaft retaining nut. DO NOT EXCEED THE SPECIFIED TIGHTENING VALUES, otherwise premature bearing failure may result.
Preferred Method
Tightening
- Tighten the nut on first pass to 150Nm (111 lb ft).
- Loosen the nut on second pass by 180 degrees.
- Tighten the nut on third pass to 425Nm (313 lb ft).
- Crimp nut.
Alternate Method
Tightening
- Tighten the nut on the third pass to 50Nm (37 lb ft).
- Tighten the nut on the fourth pass by 45 degrees.
- Crimp nut.
I‘d assume VE is the same ... maybe ...
PS: a rattle gun is a poor tool to be using to torque critical components
