Wagonman2024
- Mar 20, 2024
- 3
- 0
- 1
- Age
- 66
- Location
- Roseworthy5371
- VE wagon V6
Front door speekers dont work balance and left right set to centre are these thing fused any where?
if u can take off your door trims.. check the wires.. also make sure your doors have not filled up with water. due to the 3 drain holes at bottom being blocked. causing the speakers to short out.. this is common on the VE..Front door speekers dont work balance and left right set to centre are these thing fused any where?
whats the Fader set to on the IQ system. if set to rear you wont get anything on front speakersFront door speekers dont work balance and left right set to centre are these thing fused any where?
fader set to centrewhats the Fader set to on the IQ system. if set to rear you wont get anything on front speakers
seems strange.. as far as i know there is not a fuse for just front speakers... i would see about removing the door trim.. just check ur speakers. still unusual u have lost both speakers. it could even be the IQ system itself... maybe one of the members on here can also help.. have u got SV6 or Calais or Omega..fader set to centre
have a look on here https://forums.justcommodores.com.au/threads/stock-radio-requires-fuse.227957/seems strange.. as far as i know there is not a fuse for just front speakers... i would see about removing the door trim.. just check ur speakers. still unusual u have lost both speakers. it could even be the IQ system itself... maybe one of the members on here can also help.. have u got SV6 or Calais or Omega..
