VE Sportswagon Washer Pump?
VE_WagonII
47
VE Sportswagon
Hi All
Looked through the threads however cant confrim , does the VE Wagon have one or two window washer pumps?
I.e one pump for front windscreen washers and a second for the rear window?
Front is working however not rear, cant hear anything.
Might be pump or blown fuse??
Martbar
67
New Zealand S.I. Otago.
2016 VF Series 2 SSV Redline.
Mate, definitely a motor for the rear wiper. Check that there is fluid in the reservoir and check the fuse. Then remove the trim from inside the boot and check the connection plug. Make sure that the plug has got good contacts. No corrosion or moisture
If the fuse and wiring are OK it could be time to look at another rear wiper motor. Someone else might chime in. Good luck
krusing
Melbourne, Bayside
Hi All
They are next to each other,
"To access them easier", remove the front bumper cover,
Yes, the front bumper cover !
VE_WagonII
47
VE Sportswagon
Cheers , where is the second pump/motor for the rear washer located?
I know the front one is behind the radiator mount
To access them easier, remove the front bumper cover,
Assume same type pump is attached to the reservoir bottle for both rear and front?
krusing
Melbourne, Bayside
Yes, Next to it,
Behind the Bumper Cover.
Fu Manchu
WA.
Correct. Uses the same reservoir in the front bumper. Seperate motor. Hose goes up the A-pillar inside the car and along the roof rail to the back.
Fu Manchu
WA.
Well Krusing answered it too.
