berttybettle
I know it’s been a while but how do you fit the steering wheel? I have a vy and want to put a ve wheel on it if possible
Yep, he put a VF steering wheel in a VT Wagon...The OP hasn't been on since 2017, however I will tag @Lex, as I believe he has done a swap similar to this on his wagon...
The vy & ve steeringwheel splines are the same. If you have radio controls use the ve clock spring & the piece that goes on the back of the clockspring. Cut the loom 150 mm (6 inches) from the clockspring then cut yours (vy) of, then wire in the to correct coresponding wires .I know it’s been a while but how do you fit the steering wheel? I have a vy and want to put a ve wheel on it if possible
You can try the vy clock spring, but l dont think you'll get the steering wheel controls to work? Could be wrong though?
Yes l used the vt vx steering wheel column bolt.Just out of curiosity @Lex...Did you use your bolt to hold the later model steering wheel on?
Vy, vz, vf are the same.
I'd assume ve is the same as vy - vz? But l never checked that.
Lex, i know its been a while but do you know exactly which wires need to be connected to what? I've got a VE wheel im wanting to install onto my VYThe vy & ve steeringwheel splines are the same. If you have radio controls use the ve clock spring & the piece that goes on the back of the clockspring. Cut the loom 150 mm (6 inches) from the clockspring then cut yours (vy) of, then wire in the to correct coresponding wires .
You'll need the ve clock spring (the plug that plugs into the clock spring & some extra wiring to splice into the vy system) steering wheel & airbag.Lex, i know its been a while but do you know exactly which wires need to be connected to what? I've got a VE wheel im wanting to install onto my VY
