VE SS Ute clutch
Barberoz
71
VE SSV ute
G'day. Bought the manual ute brand new October 2008. Within 6 months the clutch was slipping. Holden replaced the whole clutch assembly from pedal to flywheel including cylinders lines and thrust bearing flywheel pressure and clutch plates. Just now pulled the motor out to "freshen It up" and discovered they replaced the dual mass flywheel with single mass flywheel!!
Has anyone else had this happen?
blackvxss
47
radelaide
VF SS, VE SS ute, VZ SS crewman, VYSS, VX SS, VTSS
yeh i had similar warranty work on my 08 ss ute holden put a ls7 clutch in. I put a NPC copper mix in mine and handles the 360rwkws nicely
losh1971
North Tas
VE Series I SS Ute
I thought the 2008 had a single mass as standard.
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
Yes.
