Ok guys a bit of an update. Am going to resolve this for people that are interested.
Did some testing tonight with a mate. The SIC module in an early VE SSV (06,07 early 08) before the change to a 3 window display can not be updated using the SPS method (software update). The only option I can change is from a Green disply to a Sports Standard RED. We took the SIC information details of a later model car and put it against my VIN (for testing only) however when uploading the update TECH2 returned an error to check ECU for compatibility. This is not the cars main ECU its the SIC ECU.
So next week I have lined up a new SIC module (later part number #92228599) and are going to fit it and see how we go. There was mention that in order for the Oil Temp to be displayed it required another sensor fitted to the sump. This is not correct as the oil level / temp sensor is one in the same and is located on the right side of the sump. The same part is use from 07 to to current.
any way I will post an update after the efforts next week.
