VE ssv redline air con issues
GTS98
VE SSV REDLINE
G’day just wandering if anyone could possibly help with a solution, my 2012 VE ssv redline has some air con issues, for the last year 3 years I’ve had no answers, I use to get it regassed every 2 to 3 months, it’s been checked thoroughly for leaks and there isn’t any, I’ve given up on paying shops to regas it all the time if there is any suggestions on what the problem could possibly that would be much appreciated. Just thought I’d check here before I think it, stuff I’ll go out and get a new compressor and condenser and see if that helps. Also side not, there is a slight whistle when I first would turn it on.
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
What are the issues you're having?
GTS98
VE SSV REDLINE
after re gassing the air con it’s only lasting 2 to 3 months, numerous leak checks done only to keep being told there is no leaks…
