VE Superlow Springs
brooksie81
34
Mooloolaba
VT SS 6.2L
Hey guys,
I have a VE Calais V and im looking to lower her on King Spring Superlows.... My question is how crucial is it that i replace the shocks at the same time? Cheers
bladerunner
"needs a bit'a nitrous"
brisbane nth
VE SS UTE & a 71' deltek rockhopper
it depends what you are interpreting as "superlow". if you mean "SL" height then no you dont need to change the shocks as "SL" is about the same height as fe2 springs- bugger all diff in other words- if you mean "SSL" or"SSSL' then yes you are better off doing the shocks as the stock ones will be past their limit resulting the bumpstops copping a belting and the car will act like a pogo stick if you hit a bump at high speed. i would suggest doing the strut top bushes while you have them out as the factory ones in the VE are crap and wont last long if you dont- providing that is if you go lower than SL. look on evil bay there are kings/monroes packages you can get reasonably cheap
RUF-60L
Donating Member
2008 VE SS
well superlow is SSL, which is what i have, so i would recommend doing both at the same time
CSP
Banned
my car
mines on SSSL and havnt replaced the shocks. its fine
For you... The extra bounce would be quite noticeable (and to me, quite annoying) though. Best off when lowering to go for new shocks to suit too.
