Lizard69
- Jul 1, 2017
- 9
- 1
- 3
- Age
- 54
- Location
- Australia
- VZ SV6
Hi i have an issue with the ECM in my VE Series 2. The ECM is fine when the engine is cold but when the engine gets to around the mid 90 degrees it fails
and kills the engine and starts getting the chatter of the throttle and relays and engine light on the dash constantly. The only code that it throws is P0513 imobilizer key. If i wait a few minutes it will start and run again until the temp gets into the 90s again.
Reading a few similar threads here they all lead to the ECM failing.
I am wondering if it a heat sink issue or component issue within the ECM. Has anyone pulled one apart, is there heatsink paste like on pc processors that may have deteriorated over time? would be a easy fix if so.
Apart from that i guess i will track down a second hand one. What is the cheapest option to write the vin and immo data to another ECM?
