VE SV6 Hard to steer
Fu Manchu
WA.
Seal kits seem cheap enough.
Mon-aro
Australia
Monaro CV8Z, VF Wagon, VF ute, VE S1, S2
Hi guys i replaced the power steering pump no change at all. ( Apart from me stuffuing up the banjo bolt washer). What should i try next please? Could it be the steering rack? Snd if so what the chances are??? Ist easy to replace " At home "?
vc commodore
Like the Leyland Brothers
VC, VH and VY
Tyres seem ok...Is that age wise, pressure wise, tread wise?
Any binding up when you have the front end off the ground, moving the front wheels?
Immortality
Staff member
Sth Auck, NZ
If it's not the pump then it really only leaves the rack.
Sorry, never changed a VE rack so I can't comment on that.
Question? Is there any electrical systems that work with the rack? Like the old variatronic system on the older models?
Mon-aro
Australia
Im sorry mate, tyre pressure is around the 33PSI mark all wheels according to my old guage
No binding and the steering wheels moves smoothly when turnin right and left
I dont think there is anything electronic.
Mon-aro
Australia
I have a donner rack should i just bite the bullet and replace it??
krusing
Melbourne, Bayside
Yes !
Its not that hard,
But make sure you have the car on ramps,
Which will help with keeping the Wheel alignment in some sort of order for the rack replacement,
But for the case of the exercise,
Take measurement's incase it turns pear shape.
PS. Grab those V8 Engine Mounts for spares.
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
When l was converting my power steering to electric p/s. l came across a symptom like yours. Very hard to turn the steering wheel.
What it turned out to be was a oring had broken on one of the pipes that go to the rack.
I had noticed there wasn't a oring on that pipe on the reassembly, so put a new oring in.
Well like yours, it was hard to turn the s/w.
I eventually took one of the pipes of (and lucky for me) it was the first one.
If it wasn't that one, l would have checked the others.
I took out the boken oring & replaced with a new one, it was all good.
If you are going to swap racks, look for a broken oring first.
Mon-aro
Australia
Hi Lex, on those bolts in the first photo?? They look like banjo bolts. I stuffed up the washer yesterday and made some mods to stop the leak. Luckily when i was looking at the donner car i saw a washed in there!
Mon-aro
Australia
Yes !
Its not that hard,
Will do for sure. Any tricks on how to remove the rack please? I just dont want to be smashing my head against the wall.
