Sstagg2005
- Jun 26, 2023
- 14
- 1
- 3
- Age
- 18
- Location
- Perth Wa
- 2009 WM Statesman L76 1999 Hsv Clubsport vt ls1
Wm/Ve statesman 6.0 litre L76
Misfires on cylinders 1,4,7 have tried changing plugs leads injectors clean fuel rail ect.
Pulled the valve covers didnt note any issues
Done a compression test all around 150 psi give or take so I’m guessing not a pushrod or anything
Also when driven it goes into safety mode/limp mode, seems to go away if light on the throttle.
Done some research into the afm i believe it is causing the issues
Anyone had anything similar?
And anyone on here put a dod delete on an L76, bonus if it was installed due to Afm causing problems. Cheers
Will update as I go I’m sure I’ve forgotten something cheers
