commyowner69
- Sep 11, 2023
- 4
- 1
- 3
- Age
- 21
- Location
- Australia
- Vf sv6
Do you know why the lower grills aren't interchangeable from series 1 to 2? The upper grills will fit with a minor clip modification as the outer shape and dimensions are the same.I know for sure that a VF one won't fit,
This is based on what I've read 'round here, and that the shape is actually different.Do you know why the lower grills aren't interchangeable from series 1 to 2? The upper grills will fit with a minor clip modification as the outer shape and dimensions are the same.
Series 2 is wider, if you look at images series 1 finish between the headlights where series 2 finishes under themDo you know why the lower grills aren't interchangeable from series 1 to 2? The upper grills will fit with a minor clip modification as the outer shape and dimensions are the same.
The upper grille is interchangeable but the lower one is not as they might look the same but the S 2 is a bit bigger.Series 2 is wider, if you look at images series 1 finish between the headlights where series 2 finishes under them
I think the Series 1 with the black trim looks pretty nice! Series 2 with the chrome trim is probably nicer than Series 1 with chrome.Ii agree, but I don't like the shape of the drl surrounds on the S1. My car is black so it's not really noticeable. Maybe it's just me . . .
