VF Seats in a VE?
Fu Manchu
Get Off Your Phone When You’re Driving.
Western Australia
Kia Sorrento, VZ Crewman, VZ Cross 8 (VE Calais)
It’s a lot of work. It’s hazardous too. The edges of the frames are sharper than my wit.
It’s tedious but simple in what to do. Takes time and patience. A bit of strength too.
So if you want easy, it’s a no go. If you aren’t shy when it comes to hard work, then have a go.
Sparkycommodore
34
USA
2009 commodore ve SSV (Pontiac g8converted)
So I have been doing a lot of research on this. I may be able to help I have all the wiring diagrams for the plugs on both seats
Now.. to do this swap there is a small angled bracket on the back of the VE seat that is riveted on. This bracket will need to be removed and re attached properly to the VF seat doing this will make the seat bolt in fine
as far as the wiring goes I am not an engineer by no means but I can give out the input that I have found on the wiring I am not able to upload the photos it won’t let me but I will happily email them to anyone interested.
seems to me like as long as you connect the wires to the counter parts on the seats should work. The other this to note is that vf seats have a lot more functions then the ve seats. Stuff like vented seats memory seats etc will not work unless wired to a toggle switch
Sparkycommodore
34
USA
Still working on my swap once I get my wiring done right I will post pictures
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
I wouldn't recommend putting 'memory seats' in a ute, a ute BCM doesn't have that function. Normal seats don't 'break over' far enough in a ute for easy access behind the seats. Makes it difficult to access the wheel change equipment or battery compartment. Magnum owners would know this...
Sparkycommodore
34
USA
Agreed just got my vf seat mounted and fastened down using the brackets riveted on the ve seats and it worked great
Fu Manchu
Western Australia
What sort of studs/rivet did you use there?
lmoengnr
Donating Member
Sunbury Vic.
