Pyrex
You wont get massive gains in bottom and midrange with exhaust or cam , there is only so much air you can get into a normally aspirated engine at lower revs.Can i get more bottom end and midrange torque solely with the full exhaust? Or is the cam essential too?
On a dyno at 3000rpm a 6.2 with full exhaust and mild cam makes about 140rwkw(made 327 at 6500rpm), stock it made about 130rwkw. The real gains started above 4000rpm , which you will agree is not bottom end. So lots of money for 10rwkw at 3000rpm.
For reference a modded Ford Barra at 3000rpm will make 200-220 rwkw (peak power 325rwkw)
If you want a car that at 2500-3000 rpm will throw you back in the seat and smoke the tires, forced induction ( supercharger or turbo) is the only way you'll achieve it.
