RevNev
- Dec 9, 2020
- 2,582
- 3,496
- 113
- Location
- Adelaide
- VF II SSV Redline Ute
It's a good practical height for a daily driver and takes the SUV look away. It doesn't necessary look lowered but looks normal where it should've been stock instead of stupidly high and works well with the stock FE2 shocks.I’m just going to get the hd and do the same set up as revnev
You'll need to wheel align the car too and I'm using FE3 or Redline specs front; -0.5 degrees camber and 1mm toe in. Rear; -0.7 degrees camber and 2mm toe in for good handling and even tyre wear. I've also played around with rear sway bars to neutralise understeer with a bit better turn in and the HSV wagon 14mm rear sway bar I found is best from the stock 12mm sway bar.
