Is there a way of finding out if you have softer shorter springs, compared to say Kings? Mine are apparently Walkinshaw and do seem soft as they won't carry 500kg in the tub without probably hitting or being close to the rear bump stops.
I have an 18mm rear SB off an Omega that I'm wondering if it might be too thick now given I have shorter coils? I was thinking Magnum 26mm front bar to even it out from a 23mm but given it's not easy to swap them out I'd prefer to have an idea before I start swapping parts.
I don't want to cause steering problems and have read by going thicker on the rear you should do the front to compensate.
Spring issue you seem to be concerned about..
2 ways I can think of that might help...
One get a set of HD springs.....Suitable if you are consistantly carrying heavy loads....
If you're not consistantly carrying loads, a pair of air bags....Can pump them up when you have a load in the tray to help stop the ass dragging on the ground....When you have no load leave them with 10 PSI in them which keeps them in good nick and is recommended....
Sway bar....I'm not going to say use this size or that size....My suggestion is more, you have driven the ute with both diametre ones fitted in the rear....You decide how it handled with both and make your choice from there..It's also your choice if you post up your thoughts....
As for helping the OP....Sorry can't....The sway bar sizes have been posted for you to decide which you'd prefer to use...
