Thanks for that, I was finding it hard to find more real racing tyres other than the ones you can get from your average tyre joint. I’ll look into these. Someone I know mentions Federals??? As a cheaper option but not sure what people think about those.
Real semi-slicks will improve times by "alot"
Don't use them on the street as you will heat cycle them to death, strictly track days
Do some googling on setting up your track tyres, invest in a temp gauge, it will help with setting up your tyre pressure and alignment settings, a "probe" type is best, but a cheap IR one will be better than nothing
For your first few outings only do 1 or 2 warm up laps followed by 3 hot laps, then pull in and check your tyre temps and pressures, you need to do this quickly, as you will lose heat fairly quickly
Look at where the tyre is wearing, and adjust from there
Once setup correctly you should get a few sessions out of a set of tyres, if they aren't set up correctly, you can kill a set in 1 session
Get a note book.
When I was "playing" racecar driver, a friend who has quite a few shiny trophies recommended that I get a note book and keep info from every track, tyre types, alignment settings, cold temp, hot temp and ambient temp
This ended up increasing tyre life and decreased lap times considerably
For an example, I'm thinking back a bit now......for either my MX5 or R33, during a club day at Wakefield Park with the "southern sporting car club" (SCC), that called for a 200tw tyre ( Hankook RS3) to be eligible to run in the street class supersprint, IIRC my cold tyre pressures were LF 28 RF 34 LR 30 RR 32 (or something like that), after 2 warm up laps all tyres were around 36-38°c
Dunlop DZ03G's were about 3 seconds a lap faster than the RS3's, I cannot remember what pressures I used but I think they liked low 30's????
Taking notes and playing around was half the fun really, well playing amateur race car driver and amateur mad scientist
I miss those days, but I've got other things that take up my time and money now
Track days are addictive and can be expensive
Enjoy
