RevNev
- Dec 9, 2020
- 2,773
- 3,851
- 113
- Location
- Adelaide
- VF II SSV Redline Ute
A bit of sidewall meaning a tyre that isn't too low in profile is easier to drive the car harder on the track as a car moving around on the tyres a bit is easier to catch when the tyre breaks traction. A low profile tyre is more like breaking traction in the wet and taller profile tyre is like breaking traction on dirt. M3/M4 BMW's are faster on 19's than 20's even with a good race driver steering the car.For track days (and you don’t care about speedo accuracy) the 40-series would have to be better; stiffer firewall & less weight, also lower … I’ve forgotten the correct term, rotational momentum (ie. the car’s fighting the tyres less when accelerating as the bulk of the tyre’s mass is closer to the axle).
Check around for available tyres though, you may find that it’s hard to find good tyres in the right size. That might end-up dictating what you go with.
*edit*
Just had a look at the Jax site; interestingly they don’t have any Michelin tyres in 245mm & 40-aspect for an 18” wheel, but they DO have a 35-series Pilot Sport Cup 2 Connect … I don’t know what the Connect part is, but the Cup 2 is a very good road+track tyre, almost a semi-slick and probably the style of tyre you’d want if the track isn’t dry. Dunno if a 35 is too small for some reason, nor if you want to focus solely on dry days & stick to slicks …
We use Cup2's on our M4 for track days 265/35x19 at the front and a 315/30x19 at the rear. The "Track Connect" one's have a sensor inbuilt into the tyre for datalogging but are otherwise the same.
Here's a set of our Cup2's virtually brand new
