1985VK
- Oct 5, 2018
- 947
- 2,370
- 93
- Location
- Australia
- VK SL
There are lots of threads about commodores running hot or overheating and lots of ideas on how to deal with it from changing the thermostat to putting in electric fans etc. An often overlooked issue is a bad fan clutch not pushing enough air. It is easy and cheap to replace.
Another thing that will make your ride run hot is a slipping harmonic balancer, especially if your volt meter is running low and are having battery problems as well ... if you are not sure put a bit of a mark on your balancer and line it up with another mark on the timing cover and crank the engine or take a drive ... if the marks have moved then the harmonic balancer is slipping on its mount and it is time to change it ...
