VK touch control panel question.
traindriver
Christchurch
85 VK Sedan 3.3 Injected
The only button used on my touchtronic panel is the rear demistor.
Can I use the other switches on the panel?
I want to install an amp for a sub and the dude at the shop suggested I install a switch in the signal circuit to let me turn the amp on and off when I want, and I thought it would be cool to be able to use the touch panel to do that.
Thanks
AndrewOfNZ
vkberlina
VK Madman
44
NSW Central Coast
www.members.westnet.com.au
The switches are momentry swiches and are low current used to control relays, control units etc for your demister, electric airial on berlina/calais, and wagons use one or two more for tail gate funtions i think wipers form memory.
You may be able to modify it to install an On/off switch.
If you want to get tricky have a look at my wiring diagrams on my site to see if you can wire up a demister control box to one of the other buttons up to drive a relay to control the remote wire on the amps.
cheers
Scott
Pub247
Melbourne S.E.
Ford Fairmont
I have seen it done in a street commodores mag a guy had a calais with his amp / sub hooked up to them so it is probably possible
VKStevo
VP Exec
i just wanna know y u want the amps hooked up to them?
VZCalZone
now choppin the VZ
vz calais, vx2 exec
Thanks
AndrewOfNZ
Which part of that didn't you get?
VKStevo
VP Exec
umm, normally the amps turn on automatically, y would u want 2 do it manually?
VRSS
34
Radelaide
VX Clubsport R8 6-Speed
Thanks
AndrewOfNZ
thats why?
VKStevo
VP Exec
ok fair enough, have fun and i hope it works 4 u
VZCalZone
now choppin the VZ
vz calais, vx2 exec
yeah i was thinkin the amp would stay on but only the sub itself would go through the button.
