- Apr 15, 2006
- 22,640
- 20,541
- 113
- Location
- Sth Auck, NZ
- HSV VS Senator, VX Calais II L67
I also have a spare memcal, it's a come racing upgrade for a VS manual. i'm not sure if swapping them out would work but would it be worth a try?
VS tune will be to suit the later 424 style PCM so won't work with the earlier 808 ECU I believe.
One thing that you can try is with the engine at running temp, remove the intake duct so you have access to the throttle body, block off the IAC port on the TB (easiest with a finger) and then adjust the idle with the butterfly screw to achieve the correct idle. Then slowly remove your finger from the IAC port and see how it goes then.
